77 head work
kevin m
11-09-2004 18:32:06
I have A 77 that I want to get A little more power out of for pulling and I have done alot to the engine short of stroking it.
How much more power will will i get if put the head on A flow rack? (stock r's)any ideas? thanx for any input. kevin
770
11-10-2004 15:33:34
 Re: 77 head work in reply to kevin m, 11-09-2004 18:32:06
my 77 head, I ported and polished the head. I LEFT THE SAME SIZE VALVES IN. Took 60 thou off of the bottom and it was good for 7 horse on the dyno. My ports now match that of a 770 manifold. I also run a tsx 755 carb. Just an idea....
kevin m.
11-10-2004 18:25:43
 Re: 77 head work in reply to 770, 11-10-2004 15:33:34
my valves are as big as i could fit, some cam work, 90 off the head compresion between 155-150. 3 3/4 - 3 3/4 bore-stroke 363 carbwhat do you think the hp is? I have A 755 on the bench, I have been to afraid to put it on the tractor runs realy strong right now. depending on the track Ihave spun out in 3rd 4500lb farm . thanx 770.
kevin
770
11-12-2004 15:13:46
 Re: 77 head work in reply to kevin m., 11-10-2004 18:25:43
I have the 3-3/4 flats also. I found more power in the head though. The tsx 755 works well with the 770 intake manifold.....I take it you have a super or 770 intake??? Making them breathe is the secret, although too much of anything can be a BAD thing. Try to find a dyno and tune on that. Thats really the only way to dial in your machine. I pull 4000-5500 lbs. All in 2nd gear due to speed limit. Plenty of power for that speed..... Good Luck!
