super 88 hydraulics
super 88
11-08-2004 08:59:13
Any suggestions for flushing out a #3 hydraulic system?? kerosene?? Lots of milk in there...
Centerplate
11-09-2004 19:01:06
 Re: super 88 hydraulics in reply to super 88, 11-08-2004 08:59:13
If you are asking what to use, I would recomend oil. The same as you use in the system. You may neeed to do it a number of times to get it clean. Also change the filter. How did the contamination get in there? Do you need new lever boots on top? Don"t forget to clean out any cylinders you used on that tractor. Or is that your source of contamination?
J.Schwiebert
11-10-2004 18:46:57
 Re: super 88 hydraulics in reply to Centerplate, 11-09-2004 19:01:06
I would take the reservoir off, take the valves off the base plate, take everything apart and wash with good hot soapy water, blow dry.Spray some rust preventer on the parts and reassemble. Centerplate gave you some good things to check. do flush the cylinder(s) and hoses.
