Cummins worth
Jaker
11-01-2004 16:50:39
I know where there is a 350 cummins out of a fire truck with an allison tranny attached to it. The engine has 900 hours on it. It was a pumper truck so I am assuming it probably has a governor on it. It runs good and the tranny is suppose to be in good shape. What would be a good price to pay for it? How much work is it to put in a 1650 with the hydrapower? Thanks Jaker
Mike (WA)
11-02-2004 08:36:24
 Re: Cummins worth in reply to Jaker, 11-01-2004 16:50:39
Didn't the numbers on the older Cummins engines refer to horsepower, and they were all physically about the same size (huge)? I think they used some of them in the big Steiger tractors and others of that size.
J.Schwiebert
11-02-2004 18:10:12
 Re: Cummins worth in reply to Mike (WA), 11-02-2004 08:36:24
Mike: That is correct. Horse power has ranged from 230 to 400 plus. All the same displacement, but after that, well get your CPL number ready.
j meyer
11-01-2004 17:39:15
as stu said, it wont work. To put a 3.9 or 5.9 Cummins into a 1650 is a headache, and I would recommend rebuilding the original engine. They are very good engines.
stu
11-01-2004 17:25:24
A 350 Cummins would be too large for a 1650. A 5.9 Cummins would be the best fit.
Jaker
11-01-2004 18:01:32
 Re: Cummins worth in reply to stu, 11-01-2004 17:25:24
Isn't a 350 cummins a 5.9 litre? I know I have read about a "big cam" 350 cummins and the regular 350. DOh, I guess a 360 would be a 5.9 hmmmm. Could you still explain the difference. Thanks Jaker
billyiron
11-01-2004 19:24:02
 Re: Cummins worth in reply to Jaker, 11-01-2004 18:01:32
the 350 cummins is a 855 cubic inch engine,lots of them in over the road trucks, im guessing it would weigh at least triple the 5.9 cummins found in dodge pickups----- ----- ----billyiron
Larry NE IL
11-01-2004 20:58:04
 Re: Cummins worth in reply to billyiron, 11-01-2004 19:24:02
With the low hrs. it's probably a big cam.
The older 350's had a way of eating themselves from the bottom up. I had an old style in a Peterbuilt that was hard on main and rod bearings. Larry
Danny Tabor
11-02-2004 12:23:25
 Re: Cummins worth in reply to Larry NE IL, 11-01-2004 20:58:04
Our local Diesel mechanic says he pays around $2500 for a "take-out" 350 big cam. He deals with the same truck yard and they may cut him a break.
If my nightmares still serve me right, the cummins has an accesory drive on the right side. Where the air compressor, oil pump everything runs off of. I forget what I needed to replace on Dad's but, Oh brother do I remember trying to hold all that in place while starting the bolts.
Larry how many miles could you get in between bearings. My CH Mack now I try to replace 'em at around 350-400,000. My old "R" model I did every 150,000. It was set up to run with the big boys. Usually at 150,000 I'd start easing up on the fuel pedal and end up burning a piston anyway. I miss the days of having a fast truck----thin wallet!
Danny
