Oliver sprayers in Iowa
Mark N.
11-01-2004 06:26:58
I'm looking to see if there are any Oliver sprayers left out there. The odds are nil but a frame of one would be fine also. I'm not sure how they were built, if they were 2 wheel units with tank running side to side or same unit with tank running front to back or 2 upright or one upright barrel like I've seen from long ago. I just want one to restore and use for spraying driveway and fenceline. I know Oliver had them as an implement but have never seen one so I'm on a mission to see what I can dig up. Thanks in advance for any responses.
luther
11-01-2004 17:10:59
 Re: Oliver sprayers in Iowa in reply to Mark N., 11-01-2004 06:26:58
I seen one on a sale about a year ago bring 150 dollars, it was a later model actually not to bad of shape still had the Oliver dealer sticker on it. I see them on sales every now and then. I come across a number of a guy selling Oliver tractors and implements - Steve Galloway, (815)-739-1221 or (815)-286-3604. Good luck!
Farmer in the Dells (WI)
11-01-2004 14:29:30
Mark, Try this:
Oliver Collector's News Oliver Rt. 1 Manvel, ND 58256-0044
bastar
11-01-2004 08:06:09
Oliver marketed several types of sprayers over the years. The early ones in the late fiftys were the old "Iron Age" sprayers. The later units were a purchased item from a company in Oelwein. IA that later became UFT (United Farm Tools). The early pull type had a channel iron frame and the UFT built units had a tubular frame. Both had the tanks mounted sideways on two wheels. Tanks were either fiberglass or poly lined steel. UFT models: 681, 125 Gallon tank, 76" fixed wheel tread. 682, 200 gallon tank, & 683, 300 gallon tank. Both 682 & 683 had telescoping frames for wheel treads of 64" to 76". There were mounted units, some with castering wheels at outter end of pivoting side monted frames.
Jim@concordfarms.
11-01-2004 07:53:08
About 12 or 15 years ago I subscribed to a little newsletter published by a guy up in North Dakota. It was called the Oliver Collector's News. One month they had a feature story on Oliver sprayers. I'm sure it would be a big help for your project, if you could find that issue. Maybe someone else on here has a copy or look on ebay. Jim.
