Oliver or White combine grain head question
Dave (MN)
10-28-2004 15:00:21
I'm looking for one of those self contained hyd. units off the back side of a Oliver or White grain head. The 1 gallon hyd. unit ran the variable speed reel with a electric wire going to the cab to control the speed. what models of heads did these units come on? Thanks.
RWT
10-29-2004 20:45:24
 Re: Oliver or White combine grain head question in reply to Dave (MN), 10-28-2004 15:00:21
For what it is worth we used to have one on a White 8800 that had an 18ft head. It was a middle 1970's model.
To control the speed it had the same kind of cable they use on chokes and fuel shut offs. It hooked to a lever inside the cab and moved a valve on the unit. It has been close to 20 years since I saw that machine but this is what I remember.
RT
ChrisL
10-28-2004 19:33:46
we have a 13' White (red one) that we used to use on our Oliver 7300 - I really don't remember the number IF it had one - only connection was the drive coupler and one one way cylinder connection to raise the reel.....nothing like you mentioned.....
