Information on Gresen pump
Fred Potts
10-26-2004 17:22:22
Looking for info on Gresen pump..I put in the wrong email address the first time . Want to know if anyone has any specs on it. It is mounted on a W4 Farmall.
J. Schwiebert
10-27-2004 04:02:23
 Re: Information on Gresen pump in reply to Fred Potts, 10-26-2004 17:22:22
Like I asked you before on where you tried and I received no answer. Anyhow you need Gresen Form SC-2000 which has part numbers and service instructions. They are vane pumps so you mostlikely need a vane & rotor kit to rebuild it plus perhaps a seal & bearing kit. YOUR BEST GRESEN DISTRIBUTORS are TRUCK Hydraulic people.Questions?
Led
10-26-2004 21:36:41
Fred, Try Surplis Center on the net. If you need a Gresen external 2 spool, 4 port, control valve OPEN CENTER. Let me know, as I changed to a CLOSED CENTER endloader.
Led
Kevin Brown
11-18-2005 06:22:08
 Re: Information on Gresen pump in reply to Led, 10-26-2004 21:36:41
Can Anybody Tell Me How The Gresen Lever Works?? I Have A 300 Series or model. It Has A Inlet, Outlet and One Spot For A Hose Hookup On The Top The Other One Has A Screw Cap On It With A Plastic Ball In It, Is This A 2 Way Lever?? I Wanted To Mount It On A log Splitter But I Need It To Go Both Ways. I Don't Know If This Does On The Lever You And Pull Back And Push Forward. But I Am Lost Here Thank You. Kevin Brown
