help
William Walling
10-25-2004 09:07:39
I bought an Oliver 88 Row Crop (?) and want to know just what I have. Numbers on dash by left knee when sitting on seat read: F88-0267 and Serial Number is 3501014. New to sight and Oliver and any help would be appreciated.
jld
10-25-2004 11:22:43
 Re: help in reply to William Walling, 10-25-2004 09:07:39
I have S/N 1032. Probably built on the same day. Have had most everything apart at least once and took alot of pics - might help in a bind if you don't find what you need in the manual. Code #'s on my plate are 88-0210 and I have no idea what they mean. It's a pretty normal tractor with hyd, pto, pulley, and final drive that let's it travel about 12 MPH. There are useable engine blocks out there if you have to have one.
J. Schwiebert
10-25-2004 09:52:36
Your tractor was made in 1953
William Walling
10-25-2004 10:32:31
 Re: help in reply to J. Schwiebert, 10-25-2004 09:52:36
Thanks, J., Now that I know it is 1953 how can I get a manual (it is diesel)? Also, is it just a plain ole Oliver 88 Row Crop? What are the numbers the other questions are referring to? What does the numbers on front plate: F88-0267 mean and how can they be used to find additional information? I want to restore and need lots of information. The block does have a crack and water comes out when put in, is this a major problem?
J. Schwiebert
10-25-2004 14:03:28
 Re: help in reply to William Walling, 10-25-2004 10:32:31
First of all on the block, shoot the next guy that tells you to stick weld it, well not relly cause I talk to Rich too. Cold crack repair using a pinning process is a lot better. Do you get water in the oil? No I can not help you with the other numbers except that system was not used until late summer of 1952 and a different spec number system was introduced with the introduction of the Super models in the summer of 1954. Also I used to work for a dealer and we were also changing tires wheel front ends, etc. thefore the options on the tractor may not have been the ones on it when it rolled out the door in Charles City. The F88 indicates the ring & pinon combination Get in tough with the museum in Charles City. May Ann can help you with an operators manual
William Walling
10-25-2004 17:04:49
 Re: help in reply to J. Schwiebert, 10-25-2004 14:03:28
Thanks again, J., no there is no water in the oil and I have ground the block down to bare metal and cleaned good and I put JB Weld on it at 5 PM today. I will let it cure and dry for the next 20 hours, do you recommend another coat over the first before I crank. One machine shop said not to put anti-freeze in for three weeks so rust would help close up crack inside (if any) does this make sense to you with your experience? If I don't need another coat can I crank it and let reach operating temp. after the 20 hours? One more thing, I hear a rattling noise in the bell housing--what service manual would you recommend for me to get and where can I find one. I have not had any luck locating one yet. Thanks again, William
ol George
10-25-2004 18:34:26
 Re: help in reply to William Walling, 10-25-2004 17:04:49
MHO on the rattle is either the throwout bearing is junk or the sleeve that holds the throwout bearing has come into, have to pull the motor or you can slip the shaft but I prefer to pull the motor.
old
10-25-2004 11:03:43
Well the crack can be a big problem but depending on how bad it is, you might be able to weld it up or like a lot of people do put J.B. weld in and it will hold for a good long time.
J.S. can tell you a lot more about what you have. I have 6 olivers in my pack of tractors they are very good tractors. As far as a manual any good tractor dealer should be able to get you an I.T. manual for it, and even this site has them.
