Rolling 1550
Jackson
07-21-1999 15:23:04
i have a 68 1550,when in any gear and in direct dive parked on an incline,it rolls down the hill.what is wrong with the hydra power?
thanks for your help!Jackson
Lyn Mn
07-26-1999 13:57:55
 Re: rolling 1550 in reply to Jackson, 07-21-1999 15:23:04
For safety always use direct drive for descending hills.underdrive will freewheel forward and could lead to an out of control situation. rolling when shut off is normal. use brake lock 3 speed hydraul and P.B. will freewheel forward also. due to sprag clutch.
Dies'l
07-22-1999 13:05:10
My 1550 and 1850 do it, too, so I'm inclined(pardon the pun) to believe it's just a trait with the Hydra Power. Maybe it needs live hydraulic pressure to remain in direct drive, and that explains the rolling when shut down on an incline.
Chris Losey
07-22-1999 21:32:12
 Re: Re: rolling 1550 in reply to Dies'l, 07-22-1999 13:05:10
That pretty much explains it. Except the hydra power is self-contained and pumps it's own oil. When you shut the tractor off the pressure bleeds off from the clutch circuit effectively leaving the unit in under-drive. This is normal for these units. Try this. If the tractor is facing down hill, put it in one of the reverse gears. This will engage the sprag clutch instead of letting it freewheel. If the tractor is facing uphill, use a forward gear and it will keep it from rolling backwards.
