Oliver 70 std
Nick van Sciver
10-21-2004 16:22:03
I have just bought a oliver 70 std.It is a 1938 it goes into all of the gears but it will only move in reverse.It will shift into 1st,2nd and 3rd,but will not move.Maybe somebody can offer some advice.Thank you
James Tierney
10-21-2004 19:42:15
 Re: Oliver 70 std in reply to Nick van Sciver , 10-21-2004 16:22:03
Does the engine pull down when you release the clutch in the non-working gears? If so, it is probably stuck in reverse. This is usally a problem with the shift lever or forks and should not be too hard to solve.
RAB
10-21-2004 16:45:26
S"easy. Sounds like just two alternatives.
1) gear selection is faulty, or
2) another problem in the gear box.
RAB
