building a motor for rc 77
tom j
10-14-2004 20:27:51
if i sleeve 9/16 over what eles can i do to make a competive puller without costing a small fortune.what about a bigger carb or govenor work.can i put a super 88 kit in my rc 77 without alot trouble, and would it be worth it.
Isaac
10-19-2004 21:22:35
 Re: building a motor for rc 77 in reply to tom j, 10-14-2004 20:27:51
I have a 1958 770. The engine was overhauled about 15 or 20 years ago. When it was overhauled they put a M&W power kit in the engine. It still has the stock head, stock carb, and stock ignition. The only mods i've done to is is put a K&N air filter on it. Mine will pull any where between 63 to 66 H.P. on the dyno turnin stock rpms. The best i ever got out of is was when i gutted the air cleaner and put dry ice in the pan of the air cleaner. It pulled just a little over 70 that time. The best thing i can tell you is when you finish your motor be shure to break it in good, that will make it the best in the long run.
770
10-15-2004 15:02:51
Tom....good luck. Here is just some ideas to kick around. On my 77 I have the 3-3/4 in. overbore in it. Port the head. LEAVE THE SAME SIZE VALVES IN UNLESS YOU"RE TURNING WICKED RPM! I shaved off 100 thou...I burn 92 or 94 octane pump gas no sweat....A mild cam and the intake and carb from a 770 (tsx 755...modified a touch). A few other cheap tricks and I dyno at 65 horse. Like I said, just ideas. The elect. ign. also helps. PS the head work I mentioned was done a year later than the rest of the work, and that was good for 7 horse on the dyno alone. My machine guy charged me only $ 100. for porting and shaving (valve job was extra)...cheap power....Huh???
WFE
10-15-2004 09:15:31
How much hp do you need? Cheapest power can be gained by, as you've already mentioned, bigger bore as long as you're overhauling anyway. Also, a rebuilt 1600/1650 carb can be made to fit on existing manifold. There are a number of different valves which can work to improve airflow; going up to at least those used on the Super series will help, but you can have automotive ones put in as well. While you're working on the head, the cheapest power gains can be had by boosting compression, which you're already doing by increasing bore, but there is more to gain by shaving the head. I've safely taken .125" from the heads, but you can no longer burn conventional 87 octane gasoline without preignition (pinging). So if you want to still burn regular gas and not the 100+ octane stuff, don't go quite that much, but do shave the head at least .040 to .050". Doing the overbore, shaving the head, bigger carb. and valves, and running rpms higher can get you pretty easily into the 80 hp neighborhood without big money. Good luck.
