46 OLIVER 60I TRANSMISION
ERIC60I
10-14-2004 18:09:50
I JUST GOT NEW TIRES ON MY 60I AND DROVE IT AROUND THE YARD.QUESTION 1. THE OLIVER PARTS BOOK SHOWES IT TO HAVE 5 FOWARD AND 2 REVERSE, ICANT FIND BUT 1,2,3 AND REV. IN A H PATTERN. QUESTION 2. WHEN IN GEAR AND START TO RELEASE THE CLUTCH THE INPUT SHAFT TO THE TRANSMISION WILL ROTATE SEVERAL TIMES BEFORE THE GEARS SEEM TO LOCK IN. ANY HELP I WOULD BE MOST GRATEFULL THANKS ERIC
shawn manck
10-21-2004 03:25:50
 Re: 46 OLIVER 60I TRANSMISION in reply to ERIC60I, 10-14-2004 18:09:50
i have the 5 speed on my oliver 60 industrial. i just got the oliver repair manual and it is the darndest shirt pattern i have seen. basically you have with the 5 speed 2 H shift patterns you have to shift from high gear and low gear with the shifter by moving it forward or back. then shift like a normal H pattern. hope this helps
