Wheels, cast/pressed steel
old
10-14-2004 09:31:19
Ok I have 4 Olivers 3 have cast centers on the rear and 1 has pressed steel which is more common and also which type are worth more?
Thanks for the info
rooster
10-15-2004 02:30:11
 Re: Wheels, cast/pressed steel in reply to old, 10-14-2004 09:31:19
From what I've seen, pressed steel is more common on a 66 than cast iron is, this is just from my experience. On a 77 it is harder to find pressed steel and on an 88 I don"t ever see any except for the people that retrofit ones for pulling. This is just what I noticed. I think most people bought a 66 when they were new because of its smaller size, not that it was cheaper than the others. There are jobs out there that require smaller (lighter) tractors. I"m sure this is why a lot of 66's had the pressed steel wheels. Jeff
RAB
10-14-2004 12:11:57
C"mon! Obviously in your case the cast are more common. In fact threee times more than the pressed steel, so it should not have been an issue for you to work out! All my 5 Olivers have cast rear wheel centres - but there again they didn"t make pressed steel centres for them when they were made. If they were the new models in late 50s onwards, I would expect they were all pressed steel as it became a cheaper manufacturing cost option. Like separate spade lug wheel options disappeared, as bolt-on or latch-on strakes and dual wheels became the vogue. So your question seems pretty irrelevant unless you are considering the one range of models when the changes were introduced.
Or am I missing something?
Regards, RAB
old
10-14-2004 12:48:08
 Re: Wheels, cast/pressed steel in reply to RAB, 10-14-2004 12:11:57
I just wanted to know since my oldest one has the pressed steel and my newer ones a 52,53,55 all have the cast. Just one of thoses question that I asked for really no other reason then to find out.
