Calcium in the wheels?
Cityslicker
10-13-2004 20:54:52
The junk yard....ahem.. tractor retirement home.. guy said the tires are filled with clacium on the Oliver 77 I just picked up...I am really dumb as far as this stuff goes (this Oliver is my first tractor) how can I remove the calcium.
Thanks for your help.
MCL
10-15-2004 09:36:09
 Re: Calcium in the wheels? in reply to Cityslicker, 10-13-2004 20:54:52
I drained fluid out a wheel on an Oliver 60 because I didn't need or want the extra weight. It didn't appear to be leaking and the rim looked O.K. I thought everything was great until a few years later I had to get the tire fixed. I got the dreaded phone call from Goodyear. They said I need to look at this rim. The rim I thought was fine from the outside wasn't so good on the inside. So even though it loooks O.K. doesn't mean everything is great. If you don't need the weight get rid of it. Why wait until you have a problem. If you need more weight get some wheel weights. That's what I do. We have two tractors with fluid. They are the White 170 and 2-105 that do the farming. The rest have been drained.
dogman
10-14-2004 15:05:07
calcium in tires was an old way of addind weight.If you drain it by no means put it back.This stuff would eat a rim off a tractor.Nowdays they use a mixture of alcohol and water.
old
10-14-2004 08:50:56
Depending on your state you can get in trouble for just draining it on the ground. Also if you are have a tire store replace the tires they will drain it for you and probably not charge you anything for doing so unless you put it back in. There money ahead for draining since they would keep it and then sell it to the next person that wanted fluid in there tires.
Dick L
10-14-2004 14:05:57
 Re: Just Wonderin ?? in reply to old, 10-14-2004 08:50:56
Calcium cloride is salt. In what states can you get into trouble putting salt or salt water on the ground? Would that be states without snow?
IanC
10-14-2004 20:10:01
 Re: Just Wonderin ?? in reply to Dick L, 10-14-2004 14:05:57
CALCIUM chloride as used for freeze protection and weight in tractor tires is A salt chemically, but the generic term "salt" is usually taken to mean table salt which is SODIUM chloride.
Dave Morlock
10-14-2004 14:47:32
Indiana for one
old
10-14-2004 14:27:06
Yes is is but, and theres the catch in some places DNR raises cane for dumping any tractor fluids even if its front the tires
VADAVE
10-14-2004 06:39:15
Just rotate the valve stem to the bottom and take out the valve. The liquid will be pushed out till the rim is sitting on the ground then put in air and repeat till the fuild is lower then the stem. Course if you want to save the calcium you have to catch it.
If you are replacing the tires the tire store will do it for you.
george md
10-13-2004 21:15:30
If it is not leaking and you are not changing tires, why would you want to take it out ?
george
Cityslicker
10-14-2004 05:21:35
 Re: Calcium in the wheels? in reply to george md, 10-13-2004 21:15:30
The tires are worn out and I am just using it for shows and things like that.
Tireman
10-14-2004 11:36:28
 Re: Calcium in the wheels? in reply to Cityslicker, 10-14-2004 05:21:35
Didn't your daddy ever tell you: "If it ain't broke don't fix it." If it has been years since the fluid was put in those tires you may be able to drain it BUT you may never get the valve stem back in or get it to seal. LEAVE IT ALONE until a tire shop works on the tires.
