Where can I find engine parts for a 1650 gas engin
Jrry
10-13-2004 08:34:00
I need rings and maybe pistons for this gas engine. They are not listed for sale on this site. Any recommendations? thanks
luther
10-14-2004 20:31:25
 Re: Where can I find engine parts for a 1650 gas e in reply to Jrry, 10-13-2004 08:34:00
I don't know who Mark is, but Mr. Schweibert can help you with all your problems, from my experence he know's one h!lluva alot about Oliver's and what makes them run!!
Mark - IN.
10-13-2004 19:57:18
 Up to speed on your problem. in reply to Jrry, 10-13-2004 08:34:00
I was gonna tell you to post here. These Oli guys take them pretty serious and when you ask specifics like that, they'll jump on in with help.
Just so you know, I don't own an Oli (not yet), but visit this forum from time to time when see an Oli that catches my eye. For now, I own an Allis and a Deere. That being said, everything I told you on the tractor forum applies across the board no matter what tractor you're operating.
Let me help you out buy getting these guys up to speed on your problem, and stay here with these guys now, they'll help you best.
PROBLEM: 1650 gas was runnin fine until changed muffler, burnin oil, running flat on a cylinder ever since.
As near as I can tell, no knocking, but suspect from the sounds of things, may've knocked or dropped or broke something loose into the manifold and may've somehow found its way to a valve or worse. But don't know yet.
You're looking for rings and maybe pistons. Have you tried checking compression yet to see which or if any cylinders are down? Before you go buying rings or pistons, you're gonna want to pull the head and you're going to have to pull the head to do pistons and rings anyway. But you've gotta start with the basics. What's the compression look like? Have you tried removing the valve cover and watched the valve train movement? Those are the simple things, do them first. Who knows, your problem may not be a cracked ring or damaged piston. You may have a stuck or bent valve and oil may be leaking down the valve stem and guide. Unless you've gotten as far as pulling the head and it's ok, I wouldn't be jumpin to conclusions that surely have bad rings and pistons. You may have a problem with a damaged piston, but it doesn't sound like you know for sure yet. Did you pull the oil pan and find metal in it? Is that why are looking for rings and pistons already? Did you check the oil for gas in it?
You're blowin oil and runnin flat on a cylinder's the last I heard, and don't know that any of these guys have heard or know that. Don't buy parts until know what parts to buy.
How's that compression? Which plug is oil fouled? What did you find that has you lookin for lower end parts?
Ralph550
10-13-2004 19:20:08
I just finished getting alot of parts for my 1650 gas, from Tom at O'Brien County Iplt and he had the best service & price I found. If you want new short block or head jobbersinc.com has that 215-236-8500 Mark or Jimmy can help with that.
Jrry
10-13-2004 14:31:57
thanks guys, now I have to take the head and oil pan off to see what all I need besides the rings.
Mark - IN
10-13-2004 20:08:09
 Oh no you don't in reply to Jrry, 10-13-2004 14:31:57
Don't get ahead of yourself there. If you haven't had either the head or oil pan off, you don't know that you need rings or pistons. Actually you don't know exactly what you need, not yet.
I posted above because you're now dealing with Oli guys that live, breath, and understand Oli's. But you gotta lay it on the line for them and run down everything that's goin on. You're gonna have these guys lookin in the wrong places, and that aint gonna help you or them.
How's that compression? How're them valves movin with the cover off? Any of them not? Any of them not actin like the others? Don't be in such a hurry to go after the bottom end until you've cleared the top end.
You're in the hands of the Oli doctors now, but gotta be straight with them before they can help.
Good luck.
Jrry
10-18-2004 11:59:29
 Re: Oh no you don't in reply to Mark - IN, 10-13-2004 20:08:09
Mark, I checked the tractor out this weekend. I checked the oil and no metal or anything else in it. I took offt the intake and exhaust manifold and checked the push rods. They were working correctly. I noticed that the no. 1,4,5, &6 had oil on them so I then checked the plugs. Only the no. 2 & 3 plugs were firing (sure seemed to be running better than that though. Anyway, I replaced the four bad plugs, but the manifolds back on and the engine started running great. After a few minutes most of the smoke was gone. I ran it again yesterday and still continued to run good. thanks for your help. I have another question if you are famalier with this tractor. What weight oil goes in the 3pt lift? thanks
Jrry
10-14-2004 06:04:40
Mark, thanks but I wasn't going to order any parts yet, just trying to get information together. I wanted to be sure that the parts were available before i tackled this. For sure I want to eliminate other sourses of the problem first because going into the engine is the last thing I want to do. I appreciate your comments and I will follow up when I have some more information. I don't have a compression tester but will probably will get one soon and I will check the valves first. I sure hope it isn't the rings/piston. I've only had the tractor a little over a week. the guy I bought it from said it ran great and the first few times I ran it it did run good. I've done a good bit of minor repairs to tractors in the last few years but I have not tackled a motor job yet.
J. Schwiebert
10-14-2004 10:53:46
 Re: Oh no you don't in reply to Jrry, 10-14-2004 06:04:40
There is a 1650 gas not too far from here that has M & W pistons in it, so the parts are totaly different. What is the problem with your engine? Could be something as simple as valve seals.
Jrry
10-18-2004 12:03:59
 Re: Oh no you don't in reply to J. Schwiebert, 10-14-2004 10:53:46
J., I provided additional information above but got the engine running good. Can you tell me what weight oil goes in the 3 pt lift. The reservoir in front of the seat was low and I added some 90 weight universal oil. The 3 pt started working but yesterday it was not working. Did I put the wrong weight in? thanks
Jrry
10-15-2004 06:02:40
J., It was running fine when I purchased it a couple weeks ago. the exhault pipe was not attached so I screwed it into the manifold and it started to smoke and oil is now coming out the manifold. I took the pipe back out but is still having oil come out the manifold and the tractor now has a miss in one or two cylnders.
old
10-13-2004 12:30:55
You could also try value bilt
Myron KY
10-13-2004 10:23:29
Here are a few places to try.
NAPA
Rick's Agri-parts
Maibach's
O'Brien County Implement
HTH
Myron KY
Ed Service
10-13-2004 10:11:27
Hy-Capacity Link These People have all you need for your engine Ed
