Super 88 Diesel Extra Switch
Ed (KS)
10-12-2004 19:35:00
On the right side of the steering wheel, under the light switch, and to the left of the fuel shutoff cable is a pull switch. From inside the dash it looks about like a light switch. Its frozen up and I haven't traced the wires yet, but can't imagine what the switch was for. Any ideas?
CWally
10-16-2004 18:20:57
 Re: Super 88 Diesel Extra Switch in reply to Ed (KS), 10-12-2004 19:35:00
Ya know, I had an 88 with the same switch. It appeared to be of a rheastat (not sure if thats spelled right) in nature however, the wire was disconnected and I could tell where it might have hooked up to. Also, I couldn't find it in the parts book. Obviously, this doesnt help a lot but it just might be original.
Super 55
10-12-2004 22:09:28
Is that your Hydra-Lectric switch?
Ed (KS)
10-13-2004 20:09:13
 Re: Super 88 Diesel Extra Switch in reply to Super 55, 10-12-2004 22:09:28
Hey Super, you know I don't know if it even has a hydra-lectic. The hydraulic system has been modified with a large reservoir and doesn't look like any of the systems described in the manual. If it is hydra-lectric, the "lectric" doesn't work. I think it works manually, at least it sounds like it does, but I haven't hooked up any implements to it yet. Thanks for the comment! Ed
