Over/Under shift available when?
Carl Day
10-10-2004 20:19:43
When did over/under shift become available? I had a 1600 and 1650 with it but am thinking about driving 1 1/2 hours to look at an 880 as a possible puller. W/O over and under it wouldn't be worth it.
Thanks
CEB
10-13-2004 14:52:22
 Re: Over/Under shift available when? in reply to Carl Day, 10-10-2004 20:19:43
My brother has a 1650D with over/under hydraul. I think its a 1968 or 1969 model. Personally, I like the over/under a lot better than the two speed. The top speed is so darned slow with the two speed. When you are running up & down the road doing one field and one field there, it sure makes the day go quicker when you can pop it in over.
evielboweviel
10-11-2004 04:10:40
1600 didn"t have over/under from factory had under only. 1650 started with under then later years over/under was available. The 880 had underdrive available as an option. Have heard it was not as strong as the later units. Good luck Ron
Carl Day
10-14-2004 20:14:02
 Re: Over/Under shift available when? in reply to evielboweviel, 10-11-2004 04:10:40
Back to the 880...do you think either the direct/under or the over/under hydraul unit would fit in place of the short shaft between bell-housing and tranny input shaft?
WFE
10-10-2004 20:47:33
Never was offered on the 880, but wouldn't that make a sweet combination... O/U first appeared in 1967, along with the introduction of the 1950-T.
Josh U
10-18-2004 11:07:44
 Re: Over/Under shift available when? in reply to WFE, 10-10-2004 20:47:33
Read the latest issue of the Hook. They put an over under in an 88. Had to extend the frame and notch it for clearance. They butchered it if you ask me. I have and 880 with the power booster that I pull with. This is a mechanical underdrive unit. (not hydraulic) It will work good if it is set up right and the sprag is not worn too bad.
