Cockshutt 30 with super high oil presure
Owen
10-09-2004 18:35:26
Recently purchased an C-30 and got it going. When cold it runs 45-50 lbs of oil presure. When is warms up it runs between 10-25 which I guess is normal. Will the cold oil presure damage anyhing like seals, ect.? The oil filter cap was loose and the oil shot out like a presure washer. Should I adjust the oil relief valve and take the presure down a notch or two or just leave it alone?
Thank your for your responses.
P Heisey
10-11-2004 03:42:30
 Re: Cockshutt 30 with super high oil presure in reply to Owen, 10-09-2004 18:35:26
Owen,
Leave the oil pressure adjustment alone. The 45 pounds of initial oil pressure is not a problem. Be thankful that your oil pressure does not drop more when at working temperatures.
Phil Heisey 215-256-8651 FAX 215-256-1203
