How do I polarize my generator?
Rob Rapose
10-07-2004 23:37:04
I just rebuilt the generator on my Cockshutt 30 and don't know how to polarize my generator. I must be doing it wrong as it's still not showing a charge. Please help!!! I'm using the tractor for it's 1st job this weekend (pulling a hay ride wagon for a charity). Thanks in advance.
J. Schwiebert
10-08-2004 07:28:33
 Re: How do I polarize my generator? in reply to Rob Rapose, 10-07-2004 23:37:04
O. K. I think your generator is an A circuit. By momentarily touching a wire from the B or Bat terminal of the regulator to the A terminal of the generator should polarize it. The spark that you see when you do this should be a nice blue color. Have yout taken the regulator out of the circuit by running a jumper wire from the F terminal of the generator to a good ground? If it charges then you have a regulator problem. Did you bench test the generator when you had it off the tractor. If not have you at least done a "motor test"? Questions? I will check this again later today I am on Eastern daylight time
J. Schwiebert
10-08-2004 07:27:27
O. K. I think your generator is an A circuit. By momentarily touching a wire from the B or Bat terminal of the regulator to the A terminal of the generator should polarize it. The spark that you see when you do this should be a nice blue color. Have yout taken the regulator out of the circuit by running a jumper wire from the F terminal of the generator to a good ground? Did you bench test the generator when you had it off the tractor. If not have you at least done a "motor test"? Questions? I will check this again later today I am on Eastern daylight time
