880 fuel transfer pump
Bill R
10-06-2004 18:37:54
I have fuel in the oil pan. Transfer pump leeking. Do I need a new pump or can it be fixs. Were can I get parts or a new pump Thanks for the help.
Josh U
10-18-2004 11:10:11
 Re: 880 fuel transfer pump in reply to Bill R, 10-06-2004 18:37:54
You can just aget a new diaphram. I forget which model, but it is the same as a newer JD.
Wes Dorhout
10-07-2004 06:56:19
Unless you want to keep it complety orignal for shows I would remove the feul pump and both filters and put on a glass filter and base.Like the later 1655,1755etc. used. It removes a lot of extra stuff on the engine and you will not have the problem of feul in the oil again. You can use your old steel lines to help make it look orignal.
Mike (WA)
10-07-2004 09:06:07
 Re: 880 fuel transfer pump in reply to Wes Dorhout, 10-07-2004 06:56:19
Don't you need a transfer pump of some kind or other, if the tractor was originally equipped with one? I had the same problem with my 550 diesel- couldn't find another transfer pump, so chucked it, put a cover over the hole, and put on a generic electric fuel pump from NAPA. Works great, cost about 30 bucks.
