570 super power steering
Ed Service
10-05-2004 10:53:53
My power steering is weak and leaks a lot. I understand leaking was a common problem on these tractors. Is there a fix for it or do you just put a piece of tin in front of the rad? Ed Service
Andrew
10-07-2004 17:36:47
 Re: 570 super power steering in reply to Ed Service, 10-05-2004 10:53:53
our old super did the same just check the rad every so offten and wash it off with the garden hoes lighty so it runs cooler i think you can get a O ring upgrade kit there higher pressure
P Heisey-Harleysville,PA
10-06-2004 04:15:28
Ed Service,
I have the O-ring power steering head seal kits and upper/lower main shaft seals in stock for Cockshutt 550, 560, 570, and 570Super tractors.
Phil Heisey 215-256-8651(eve.) FAX 215-256-1203
