loader for 1650.
Jim@concordfarms
10-05-2004 09:02:00
Neighbor who always did all my loader work for me just retired and sold his loader tractor, so I'm on my own now. It was a good arrangement, he did my manure loading and bale moving, and I did his baling. Most logical of my tractors for a loader is my 1650. I think the reason I've never put a loader on it is because of the hydra-lectric system. I assume what ever I get should have it's own PTO pump. Also, I want something with a quick detach bucket and arms. What's your advice? Thanks for any help. Jim.
Sam M
10-06-2004 11:32:21
 Re: loader for 1650. in reply to Jim@concordfarms, 10-05-2004 09:02:00
I put a Bush Hog loader on my 1555 and eventually went to a PTO pump because the hydraulic pump on my tractor was too weak to operate the loader especially with the heavy round bales I am feeding . The best way to go is the power beyond set up with a separate joy stick valve to control the loader . While the PTO pump is definately strong since it is only running the loader , the problem with PTO pump is you need a separate reservoir of hydraulic fluid (with extra cost of its own filter and fluid ) AND the PTO pump manufactuers recommend the reservoir should be at least the same size as the gallons per minute flow of the pump's circulation . For example , if the pump circulates 12 gallons per minute the reservoir needs to have 12 gallons of hydraulic fluid OR a hydraulic oil cooler needs to be installed in the PTO pump circuit . If you do not do one of these , the PTO pump manufacturers claim the hydraulic fluid will overheat and wear out . With the PTO pump and reservoir , you also have the problem of where to mount the reservoir and how that will affect quick detaching/attaching the loader . I ended up just leaving the loader on my 1555 all the time .
Shovelman
10-05-2004 16:56:45
Jim,
I mounted a John Deere #48 detachable loader on my 1650 last spring. I had to modify the brackets and change the control valve over from closed center to open center.
I followed the advice of several experts on this board and set up power-beyond off the 1650's hydraulics for the loader. It works great.
It can be installed or removed from the tractor in about five minutes.
The loader is a good match for the tractor and it looks good as well. I painted it up Meadow Green and put some Oliver decals on it. Unless you were a Deere or Oliver purist, you would probably think it was original.
Good luck,
Scott Goff
CEB
10-05-2004 15:07:01
Jim,
You don't need another pump on a 1650. Oliver factory hydraulics are plenty good to run any loader. I agree with mapleman, a nice auxillary control valve hooked up to power beyond would sure do the trick. A one handle joystick valve would be nicer yet. I believe if you look in the archives on this site, someone put out very nice easy to follow directions (with pictures) on where to hookup for power beyond. Oliver Power forever!! Good luck.
mapleman
10-05-2004 09:44:04
pto pump is one way to go. but on our 1655 - we decided to change the setup to a power beyond - works REALLY well. reaosn being we wanted to be able to use the PTO when using the loader. we ended up putting a 3-spooler on - so we can have a hugger hooked up. i dont know how fast the pto pump would be - maybe faster. so it depends on your intended uses. i believe, should yoiu decide to go down the power beyond road, that the 1650 can be hooekd up this way - our 1655 can and 1850s can too. good luck.
