770 LOADER CYLINDER
DOUG D
10-04-2004 16:53:13
I HAVE A 770 INDUSTRIAL WITH A FRONT LOADER THAT WAS MADE BY WARE FOR OLIVER.I DAMAGED ONE OF THE CYLINDERS THAT DUMPS THE BUCKET, THE BARREL IS OKAY AND I CAN REPLACE THE SHAFT, BUT THE NUT THAT OUTER SEALS ARE IN IS BROKEN AND I HAVENT HAD MUCH LUCK IN FINDING ONE. ANY HELP OR TIPS TO FIND ONE IS APPRECIATED,THANK YOU.IF YOU HAVE INFO CALL 805 717 3443.
RickL
10-05-2004 06:36:07
 Re: 770 LOADER CYLINDER in reply to DOUG D, 10-04-2004 16:53:13
I have a bucket cylinder off a 1610 Oliver loader if that would help. I don't know if they would be the same or not thou. RickL
DOUGD
10-19-2004 10:07:10
 Re: 770 LOADER CYLINDER in reply to RickL, 10-05-2004 06:36:07
RICK L,GIVE ME SOME MEASUREMENTS ON THE CYLINDER YOU HAVE, MAYBE ITS THE SAME OR CLOSE. SINCE MY COMPUTER ACCESS IS LIMITED AT THIS TIME, EITHER CALL ME AT 805 717 3443 OR POST A RESPONSE TO THIS MESSAGE AND ILL SEE IT WHEN I CAN, THANKS.
B A Star
10-04-2004 22:26:14
It is my understanding that Ware is still in business and still has parts for the equipment that they built. They are located in Massachusetts. Do a search and you will probably find them.
