Oliver hydraulic cylinders
Nate88
10-04-2004 16:47:35
Does anyone know if Oliver built their own hydraulic cylinders? These days most equipment manufacturers buy cylinders from another company. I acquired a few cylinders, hydra-lectric, and would like some more information on them. Thanks.
RickL
10-05-2004 06:33:41
 Re: Oliver hydraulic cylinders in reply to Nate88, 10-04-2004 16:47:35
I have an Oliver cylinder they I need to get rid of if you would be interested. It looks alright the way it is. I just don't need it.RickL
Nate88
10-05-2004 16:39:16
 Re: Oliver hydraulic cylinders in reply to RickL, 10-05-2004 06:33:41
Where are you located at? I am in Lafayette IN. I have three cylinders, but if it is close I might be interested in another. Thanks.
RickL
10-06-2004 05:59:48
 Re: Oliver hydraulic cylinders in reply to Nate88, 10-05-2004 16:39:16
Located in southeast Iowa
Nate88
10-06-2004 15:06:13
 Re: Oliver hydraulic cylinders in reply to RickL, 10-06-2004 05:59:48
I think I will be ok with 3 cylinders. For more information I did take a closer look at the cylinders. Two of them are welded cases and the other is a casting. The one with the larger rod is a casting and the head is bolted on. The cylinders with smaller rods have threaded heads. I will find out more once they are actually torn apart. That is when I get some time.
J. Schwiebert
10-04-2004 19:45:27
Yes they did make there own hydra-lectric cylinders. Now you tell me if you have the steel tube cylinders or the cast hydra lectric cylinders. If you have the steel cylinder, they were built in three different diameters. Also the very first ones have "fingers" instead of the internal magnets. Questions?
Nate88
10-04-2004 19:57:14
 Re: Oliver hydraulic cylinders in reply to J. Schwiebert, 10-04-2004 19:45:27
Off the top of my head I don't remember if they were cast or not. I will check tomorrow. I haven't dug into them yet. I know two of them will need new rods as they are rusted and pitted. The other is collapsed and may be ok. I'm sure they will all need new seals. I believe they are all 3" diameter bore. Two have 1" diameter rods, and the other I think is 1-1/2". I'll know more when I start rebuilding them. Thanks.
