Super 88 Questions
Ed (KS)
10-02-2004 19:53:25
1955 Super 88 Diesel. First: what is the small brass valve or petcock on the middle outside of the air intake manifold for. I can't find anything on it in the owners or shop manual. Should it be open or shut?
Second: Someone has replaced the top cover of the hydraulic pump with a large cylindrical reservoir, looks to hold maybe an extra gallon and a half of fluid. Can anyone tell me the purpose of this modification? Thanks and regards! Ed
cobroller
10-03-2004 09:36:31
 Re: Super 88 Questions in reply to Ed (KS), 10-02-2004 19:53:25
The petcock was probably used as a place to spray ether in to the manifold. Diesels don"t normally have enough vaccum to operate a milking machine. The petcock should be kept closed.
Nick in dairyland
10-03-2004 06:57:56
My dad had rigged up our Oliver 88 just like that to milk cows when the electricity went out. We ran the tractor half throttle and hooked a hose to the vacuum line. It would pull two milker buckets. Beat the heck out of hand milking them all.
Ed (KS)
10-04-2004 18:02:12
 Hey Nick! in reply to Nick in dairyland, 10-03-2004 06:57:56
You wouldn't pull a fellow's leg would you? Its been many years since I chased a skyhook or a bolt-stretcher! Regards! Ed
J.Schwiebert
10-02-2004 19:56:35
Most likely it had a loader that had single acting cylinders and there was not enough oil capacity so a supplemental reservoir was needed,
