Took a peek(Super 88)
Jak
09-30-2004 11:01:12
I thought I would change the spark plugs on the 88 and grabbed the flash light and peeked in.To my surprise I found a half dome on the plug side of the pistons.It has always felt strong but I can't seem to stop the black smoking at idle.I have heard that the domed pistons may disrupt the explosion in the cylinder.Is there much truth to this?It runs real well when it's under a load.
Jeff Oliver
09-30-2004 17:46:35
 Re: Took a peek(Super 88) in reply to Jak, 09-30-2004 11:01:12
Alright! that did it! ya got dome pistons huh? Weeellll.. guess I'll just have to add some more mouse cages under my side panels then..Ooopps I forgot, I don't have any side panels!! LOL!!!! Hehe well one of these days when I decide to pull in something besides first I might have to through a set of those in mine also. You gonna carry it to Tunica? I think there is a pull in Ms this weekend at Sugarland Farms? I though about going until I had my truck fixed then filled it up..:(
Jak
10-01-2004 13:28:25
 Re: Took a peek(Super 88) in reply to Jeff Oliver, 09-30-2004 17:46:35
Jeff I just had a brainstorm,take the 1800 engine out and just drop her in that 88 and with a few modifications you will have a hoss,whatcha think?
Jak
10-01-2004 07:19:58
I will go to Tunica just not sure about takin one yet.Come on and go with,you'll get enough tractor pulling to do ya for a while,they have a big turnout.I read the rules for Burton Sugar farm Midsouth Flywheelers that said 1st gear only so you should be in good shape there but if they decide to use Al's rules you could go second as long as you don't break 3.5mph.
John P.
09-30-2004 11:14:09
It sounds more like you need to either adjust the carburetor"s low speed circuit, or rebuild it if that does not work (assuming the ignition system is in tune).
