Possible governor troubles now!
Can't even use
09-29-2004 15:06:07
So she runs fine while unloading about 5 loads of silage then suddenly I can't get any more throttle than maybe 1/4. Crawled home and shut it off to investigate, moved lever and the linkages all moved normally and the butterfly was opening all the way up. Started it up again and now it won't move the butterfly. Shut it off and all is good. Start it up and manually move linkage directly connected to butterfly and it is pulling back on it! Let it set for a few hours while I do one of a hundred other things on the list and come back to have another look. Start it up and all is good again. What is up with this thing, something to do with the heat? And what is the deal with the slots in the pulley on the crankshaft, what do they adjust for? Thanks for any help again!
