Got that carb fixed on the 77 finally
Can't even use
09-28-2004 20:13:00
Just wanted to let ya'll know that I finally got this carb licked on the ole 77. Ended up after rebuilding the thing it still ran gas over. Found out that the float was more of a sinker! No hole but somehow the two floats were caved in. Never filled with gas but boy did it drop when put in a bucket of water. Got a new one and she runs like a top! Thanks for all the help.
B A Star
09-28-2004 21:09:49
 Re: Got that carb fixed on the 77 finally in reply to Can't even use my name, 09-28-2004 20:13:00
The carb has had water in it at sometime and froze when it got cold. Use your smallest drill bit and drill a little hole in the floats and a little air will expand them back out. Solder the holes shut and you have a spare float.
RAB
09-28-2004 22:39:59
 Re: Got that carb fixed on the 77 finally in reply to B A Star, 09-28-2004 21:09:49
Try no hole and hot water first. May just pop out.
Regards, RAB
Can't even use my na;me
09-29-2004 05:58:45
 Re: Got that carb fixed on the 77 finally in reply to RAB, 09-28-2004 22:39:59
Thanks fellas, I had thought about trying both of these tricks too. Seems like one should work. I am just glad she is back to work. Guess the guy I got her from just didn't want to take the time to figure out what was wrong. Cheap tractor for me!
Loren
10-05-2004 18:02:04
 Re: Got that carb fixed on the 77 finally in reply to Can't even use my na;me, 09-29-2004 05:58:45
I replaced the float in my 77 due to the same thing. Mine were crushed due to backfires.
