Oliver 88 diesel
Patrick Cavanau
09-28-2004 16:10:50
how would you go about hooking up a kill switch for a 49 Oliver 88 diesel? the original was completely rusted out when i bought it and i've tried hooking a pull switch to the idler spring but that made it stick.
slowsmoke
10-01-2004 05:22:48
 Re: Oliver 88 diesel in reply to Patrick Cavanaugh, 09-28-2004 16:10:50
Use a choke cable to the back of the tractor. tie it in to the normal shut off piont at the pump with a wire tie (or anything the would break before pump damage) SS
jld
09-28-2004 17:13:19
The cable is available thru Agco and the chain and block from Korves. -- or you can adjust the throttle linkage so it shuts off in the top one or two quadrant notches.
If you are talking puller tractors, then I'm not sure what you need.
