Fleetline 88 with a 1750 roosa-master pump
old
09-27-2004 19:24:56
Ok I know what it is now how do I turn it down?? If you pull the throttle back about four notches it sounds like it is running as fast as it should. I'd like to be able to use it from the first notch to the last with out blowing it up. Or is there some one out there that would like a tractor for a puller?? I plan to keep the wide front and put a trike front on and I might keep the 3 point. It runs good but doesn't seem to be much good for the farm at least not yet
Wes Dorhout
09-30-2004 18:25:58
 Re: Fleetline 88 with a 1750 roosa-master pump in reply to old, 09-27-2004 19:24:56
You need to use a different bell crank under the feul tank. I should have the one you need.
