carb on 60 i
eric60i
09-26-2004 17:28:11
just started up for the first time since i found it in a junk yard. it started up real quick no smoke no strange sounds, but it wants to run only with the chock fully closed. i cleaner the carb real good but did not change any parts. what should i do? thanks eric
shawn manck
09-30-2004 22:25:32
 Re: carb on 60 i in reply to eric60i, 09-26-2004 17:28:11
check and make sure that your fuel lines are clean and are not restricted, it sounds like it isn't getting enough gas from the tank to the carb
evielboweviel
09-26-2004 18:15:09
clean it again paying close attention to samll passageways. or you have an air leak and need to run full choke to compensate.
Ron
