PTO on oliver 77 not stayin ON
Can't even use
09-26-2004 17:19:42
Got the girl running ok right now, needs a cap and rotor and some more carb adj but now the pto lever won't stay snapped ON under load. Will stay there without being hooked to anything. Is there some adj or what. Thanks again ya'll.
Geoffrey in KS
09-26-2004 18:55:43
 Re: PTO on oliver 77 not stayin ON in reply to Can't even use my name, 09-26-2004 17:19:42
First things first. Do you have a manual? I can't stress that enough. I prefer the Oliver manual to the I&T manuals.
It sounds like it is just out of adjustment. Take the cover off the pto unit. There should be four bolts going into the bottom of it. When that is off, you will see the clutch assembly. There are three sets of shims spaced evenly around it. Loosen the bolts and take a couple shims out of each pack. Always take the same number of shims out of each shim pack. Put it all back together and see if the lever snaps over center and stays there correctly. It should take some pressure to snap it over, but not a great amount. If it does snap over, you're done, but if not take a couple more shims out and retry.
???'s let me know.
