Super 88 Diesel Fuel Filter
Ed (KS)
09-24-2004 08:46:21
The owners manual says the secondary (or final) fuel filter should be changed by an Oliver serviceman at the dealership. Was this just a reason to get folks into the dealership... or is there a valid reason to do this?
Geoffrey in KS
09-24-2004 19:36:42
 Re: Super 88 Diesel Fuel Filter in reply to Ed (KS), 09-24-2004 08:46:21
Hi Ed. Nice meeting you in Ottawa the other day. Bring that down to Osage City for a while and I'll change the filter so long as I get to play with it for a couple days first.
Ed (KS)
09-25-2004 10:51:20
 Re: Super 88 Diesel Fuel Filter in reply to Geoffrey in KS, 09-24-2004 19:36:42
Hey Geoffrey! How you doing man? I'm pretty sure I can get that filter changed, but I just wanted to see if anybody knew why that warning was in the manual. Look forward to seein you again! Got that Super 77 goin yet? Regards! Ed
Geoffrey in KS
09-25-2004 19:00:31
 Re: Super 88 Diesel Fuel Filter in reply to Ed (KS), 09-25-2004 10:51:20
No the Super 77 isn't up and running yet. It will be the end of the month before the hydraulic center plate is available for shipment. Then I'll get it going.
Geoffrey
Nate88
09-24-2004 16:38:05
I believe that would be a reason to get folks into the dealership. I have Super 88 diesel and the final filter is located on the left side of the engine just behind the injector pump. Changing this requires keeping all the lines and fittings tight. You also do not want to get air in the pump and cause an airlock. I"m sure most folks did this themselves. You just have to take your time and don"t get air in the lines. Just like any diesel.
J. Schwiebert
09-24-2004 18:22:59
 Re: Super 88 Diesel Fuel Filter in reply to Nate88, 09-24-2004 16:38:05
The first ones also had a check valve in the filter. If it was put on upside down the engine would not run. The filter has had several different changes. The later Bosch filter with the part number 90910 was a very good filter.
