Oliver 550 Pto Lever Location
Kman
09-23-2004 19:47:11
I was looking at a 550 that a someone wants to sell and noticed the PTO lever was on the right below the dash. I thought the lever was like the row crops in the back on the right? The serial number says it's a 1958. Did they change this at some point and would this tractor have a separate PTO clutch with the lever located here?
MCL in IN
09-24-2004 09:20:47
 Re: Oliver 550 Pto Lever Location in reply to Kman, 09-23-2004 19:47:11
We bought a later model 550 when I was a kid in the early 80's. It had the front PTO lever. We put a Freeman loader on it and had to change to the rear lever because it interfered with the loader. Now the loader is gone and the front lever is back on it.
J. Schwiebert
09-24-2004 01:10:51
The later ones were in the front, It is a 1958 with the handle someone purchased the kit to convert. I am not sure when the front handle was made available but it was a lot later than 59. 1958 models also still have the smaller engine too. Super 55 replied and he has an early one with maybe the short handle and they had a kit to change it if you wanted too.
ShepFL
09-23-2004 20:13:17
If my research is right the front mounted PTO handle started in 1959 and continued into the late 60's. My only beef with it is when you push in the clutch it will CRACK you knee cap just about everytime. I have learned to lean knee in when engaging clutch.
Super 55
09-23-2004 22:26:17
 Re: Oliver 550 Pto Lever Location in reply to ShepFL, 09-23-2004 20:13:17
Hey, you learn something new every day. I had no idea that there were fron mounted pto levers. I'll have to look for that at the next show.
Hope you get some good weather down your way soon. I think Florida has had just about enough of the big blow.
