77 oliver
sam in mo
09-23-2004 18:26:12
does anyone know if you can put a hyd system on a 77 oliver and if so how does it (the pump) hook up to the motor? Also does any one have a complete system for sale? thanks sam
anothertractor
09-28-2004 10:09:41
 Re: 77 oliver in reply to sam in mo, 09-23-2004 18:26:12
Hey Sam,
I have a hyd unit that I would sell. E-mail me at [email protected]
Thanks,
keith
old
09-23-2004 21:35:14
I have a 77 with hyd that I might trade for your 77 with out and I'm in missouri
oleblu
09-23-2004 20:12:53
Sam, yes you can put a hydraulic system on a 77. The unit goes under the steering wheel, you probably have just a cover or a "manual" lift there now. To put hyd on you first pull the PTO shaft out (it's about 5' long), remove whatever is there now, andput on your unit. The pump is on the bottom of the unit and is driven from the PTO shaft that you will put in last. Drop me an e-mail if you need more info. If you know any tractor pullers with 77, 88, Super 77 , Super 88, 770, or 880 ask if they have a unit for sale. They usually take them off to get their tractor lighter.
evielboweviel
09-24-2004 04:15:03
 Re: 77 oliver in reply to oleblu, 09-23-2004 20:12:53
if the tractor has a mech lift the tranny input shaft is too long. this is covered in the service manual. I didn't remove the tranny input shaft instead cut it in place. a lot of rags under it, ran a vacumn the whole time and flushed the tranny three times afterwards. also an early trans oil change for the next time.
Ron
