77 connecting rod torque specs
Can't even use
09-23-2004 18:16:25
Just about to put this girl back together! Need the torque specs for the connecting rod retaining caps. Thanks a million in advance.
Super 55
09-23-2004 22:34:34
 Re: 77 connecting rod torque specs in reply to Can't even use my own nam, 09-23-2004 18:16:25
Seciton 2 page 23 of the manual says 77 connecting rod torque is 46-50 foot pounds.
Manual also says to install caps on the bearings in the order they were removed.
RAB
09-24-2004 08:56:12
 Re: 77 connecting rod torque specs in reply to Super 55, 09-23-2004 22:34:34
Presumably they tell you, somewhere else, which order to remove them?
I would have thought that it was much more important to replace them on the same journals/crankpins, and the right way round, than in a particular order!!
OK for mains but what if you only want to remove one piston and it happens to be the last in the list!!!
Failing that, the American language has diverged from English more than I had realised.
Regards, RAB
09-24-2004 13:38:25
 Re: 77 connecting rod torque specs in reply to RAB, 09-24-2004 08:56:12
You must be a pratical joker or a smarta$$! Either way I like it.
09-24-2004 06:13:06
Thankyou much! Will torque down today and then work on the top end.
