60 ind.
eric60i
09-22-2004 18:53:01
i just found a starter and now need help with the electrical hook up. i do not have any fire to points or plugs. i ordered an electronic ingition and high out put coil (12v) what else do i need to change or do to get fire to the plugs? i think that it came with a 6v system?
generator not hookup and no guages yet. can i hook it up to a battery and try to get it to run? thanks eric
shawn manck
09-30-2004 22:34:46
 Re: 60 ind. in reply to eric60i, 09-22-2004 18:53:01
i had the same prob with my industrial wiring isn't hard. all your power should come from the starter switch that comes from your battery(as far as i can tell with mine) then go to a togggle switch, then to the positive side of your coil. the hard part is wiring for the light switch i haven't got one on mine yet since i have the engine apart right now and rebuilding it
