Oliver 80 std low radiator
oliver puller
07-14-1999 10:24:09
I have a 1937 low Radiator oliver 80 std. that i pull in colorado. I would like to know how many where made. I know in 1938 they went to a higher to tank on the radiator and gass tank but i would like to know who many low radiators 80 stds where made.
Troy
07-14-1999 12:25:23
 Re: oliver 80 std low radiator in reply to oliver puller , 07-14-1999 10:24:09
How does it pull? Did you do anything special to get it to pull better? What weight do you pull at? I could look up the serial numbers for you and determine how many were made in 1937 and 1938 if that would answer your question. I always wondered if you did something to raise the compress ratio if they would make pretty good Pullers. They are still kind of heavy though. What would be the easiest way to raise the compression ratio?
