330 waukesha
jerryh
09-20-2004 07:15:41
I Have a 330 that is on an irrigation unit, it has external oil cooler. What I was wanting to know is would or has anyone used this motor in a tractor and how was it compared to a 310.
jerryh
09-20-2004 15:41:07
 Re: 330 waukesha in reply to jerryh, 09-20-2004 07:15:41
I posted some pics in parts n pieces, mail is unlocked also.Jerryh
880 diesel puller
09-21-2004 10:47:51
 Re: 330 waukesha in reply to jerryh, 09-20-2004 15:41:07
Do you know where I might find one of these for sale? I am in southern IN.
jerryh
09-21-2004 11:39:44
 Re: 330 waukesha in reply to 880 diesel puller, 09-21-2004 10:47:51
I would sell it but I would sure like to know what kind of HP you finally got out of it.I would take $1500 for it and you can hear it run. It is in S.E.MO
880 diesel puller
09-22-2004 11:44:52
 Re: 330 waukesha in reply to jerryh, 09-21-2004 11:39:44
I am very interested in talking to you. If you would please call me tonight so Ican find out more specifics. My # is {812}-431-2387.
tractor pullerks
09-20-2004 07:46:25
i wounder if there is a diffrece between 330 and a 320 wakishaw engine do you have pic of it and is the head a cross flow head i heard they were.
J. Schwiebert
09-20-2004 07:54:59
 Re: 330 waukesha in reply to tractor pullerks, 09-20-2004 07:46:25
I can answer part of that. The 320 is an updated 195 with out sleeves. It has a 4.250 bore and 4 inch stroke. The 330 is 3.875 bore (wet sleeve) and has a slightly longer stroke than a 310
tractor pullerks
09-20-2004 09:06:14
 Re: 330 waukesha in reply to J. Schwiebert, 09-20-2004 07:54:59
i wounder if a 354 perkins crank will fit in the 320 or will the 330 crank work to gain stroke. i am building a 320 and want to put a cam over the top , this320 is a propain molde and i wounder if there is a diffrents in that to i havent tore it down yet, was the head bigger then the 320 gas and is the 330 head a cross flow and is is a bigger ported head just looking at options
J. Schwiebert
09-20-2004 13:23:58
 Re: 330 waukesha in reply to tractor pullerks, 09-20-2004 09:06:14
Are you just thinking outloud or have you taken some carefull measurements on this stuff like the Perkins crank.Have you compared the cost of building a stroker crank? I think there are more 400 plus cubic inch 88 engines around than what you think. I was in another shop by request of a customer to look at some cracked heads of another brand. They were building a 4.250 bore 88 engine and he also had a 310 diesel (cross flow) set sup with spark plugs.
tractor pullerks
09-20-2004 20:20:27
 Re: 330 waukesha in reply to J. Schwiebert, 09-20-2004 13:23:58
just wounding how hard would it be to put the cam on the top side of the head.
J. Schwiebert
09-21-2004 08:53:52
 Re: 330 waukesha in reply to tractor pullerks, 09-20-2004 20:20:27
Are you thinking of an aluminum carrier like some automotive heads use?
tractor pullerks
09-21-2004 08:58:38
 Re: 330 waukesha in reply to J. Schwiebert, 09-21-2004 08:53:52
that might work , i have a friend that has already done this with a cam on a 330 head , but i havent seen it yet, he has a lot of dollers in this head. looking for options somthing new,
