HG vs OC3
marv in minn
09-20-2004 06:22:41
i'm thinking of getting a small crawler.
what are the differences between a HG and an OC3?
is one prefered over the other?
thanks, marv
T!ROY
09-24-2004 23:54:16
 Re: HG vs OC3 in reply to marv in minn, 09-20-2004 06:22:41
Gentle men this is only a 20hp machine. please quit repowering with car and truck engines. These were built as farm tractors. Plenty of collectors out there will take your problems away from you. Try M&R Track service 800-564-0383 has plenty of parts and complete machines.
Ed Service
09-22-2004 18:03:10
Who all have repowered an hg? I have one with a sick engine and have considered repowering it with a more modern powerplant. (Even a Briggs and Stratton would have more power!) Any thoughts and or recomendations? I once saw one with a Datsun engine in it complete with the datsun 5 speed! Kinda crude but it worked and the owner fabricator was sure proud of it! Thanks, Ed Service
marv in minn
09-23-2004 04:40:16
 Re: HG vs OC3 in reply to Ed Service, 09-22-2004 18:03:10
i'm looking for an HG or an OC3 chassis to repower.
i have a power unit begging for a chassis to run in.
thanks, marv
RAB
09-20-2004 09:21:31
HG"s became OC3"s when Oliver eventually changed numbers, colours, etc. after buying out Cletrac. The OC"s should be better than the older HG"s - younger (and not so worn out?) and they would have the later modifications, such as later pump cooled engines, different front idler arrangement.
They are a small crawler, not a very good dozer - unless the gearing on the HG"s is reduced with an auxillary transmission. Don"t know if there was a low geared OC3 for dozer work. The early HG"s which did not have outboard bearings in the track drive gears are not really suitable to fit a reduction gearbox to, if they are to be used at full torque (maxpower and slowest speed)
Hope this helps.
Regards, RAB
