adjust tappet clearance
Ernest Donato
09-19-2004 15:39:07
I'm trying to adjust tappet clearance on my 1952 Oliver 70 row crop tractor! It is a straight 6 cylinder engine and there is a panel on the side that allows you to adjust the tappets, but I don't know what the cearance is for the exhaust valves and the intake valves! Can some one help me with this?
RAB
09-20-2004 09:26:28
 Re: adjust tappet clearance in reply to Ernest Donato, 09-19-2004 15:39:07
Tune up specs. Left side of the page.
RAB
erny
09-20-2004 10:11:15
 Re: adjust tappet clearance in reply to RAB, 09-20-2004 09:26:28
Thanks I will try to do it now! Intake and exhaust are both .011 And it can be done while running right? I didn't know it was a 48
RAB
09-22-2004 08:54:27
 Re: adjust tappet clearance in reply to erny, 09-20-2004 10:11:15
Erny,
He didn"t say it WAS a "48, just that it couldn"t be a "52 as they stopped making them in "48.
Need to know the serial number to give it a year of manufacture.
Regards, RAB
J. Schwiebert
09-20-2004 13:30:04
Both intake & exhaust are set the same. Much easier to do with engine off. Remember at room temperature.
J. Schwiebert
09-20-2004 09:30:36
70 Valve clearance is adjusted by the adjusting screws in the rocker arms under the valve cover not on the side by the tappet cover . Average clearance is 0.011 or 0.012 with engine at room temperature. 1948 was the last year of 70 production.
