Oliver Super 55 3 pt. hitch height adjustment?
Peter Frey
09-17-2004 07:47:20
I was recently given a V style drag snowblower for my tractor but my problem is the 3 pt. hitch won't come up high enough to lift it off the ground. Is there any way to adjust how high the hitch goes.
Any help would be appreciated.
Larry from MD
09-17-2004 09:12:27
 Re: Oliver Super 55 3 pt. hitch height adjustment? in reply to Peter Frey, 09-17-2004 07:47:20
Yes but its inside the unit.Try shifting the lever into draft control.If it lifts high than the internal ajustment is off.
Peter Frey
09-17-2004 09:44:42
 Re: Oliver Super 55 3 pt. hitch height adjustment? in reply to Larry from MD, 09-17-2004 09:12:27
Thanks for your reply Larry. I am not very familiar with this tractor. How do I shift the lever into draft control?
J. Schwiebert
09-17-2004 10:50:18
 Re: Oliver Super 55 3 pt. hitch height adjustment? in reply to Peter Frey, 09-17-2004 09:44:42
Larry gave you good advice, but later Super 55 tractors have a double feedback system and if I remember correctly that adjustment is external. There should be a serial number down by the clutch petal on a metal plate. How about giving that to us and also if your hydraulic filter is in front of the unit or on the side.
Peter Frey
09-19-2004 05:10:52
 Re: Oliver Super 55 3 pt. hitch height adjustment? in reply to J. Schwiebert, 09-17-2004 10:50:18
When I switch the draft control lever up the hitch drops all the way down so it must be on when its working. What is the draft control supposed to do?
The hydraulic filter is on the side of the unit. The spec. # is 15-0065 and the the ser. # is 181394518.
Thanks for the help.
J. Schwiebert
09-19-2004 16:19:07
 Re: Oliver Super 55 3 pt. hitch height adjustment? in reply to Peter Frey, 09-19-2004 05:10:52
Position control is for implements like mower choppers,etc. Draft control is primarily for a plow. Send me a U. S. Mail address and i will send you some information.
Peter Frey
09-19-2004 19:46:44
 Re: Oliver Super 55 3 pt. hitch height adjustment? in reply to J. Schwiebert, 09-19-2004 16:19:07
Thanks. Can you mail to Canada?
My address is Peter Frey, 720 Conc. 3 West, RR #1, Wyevale, ON, Canada. L0L 2T0.
Any information is very much appreciated.
Larry from MD
09-17-2004 15:01:05
If you have the lever it is behind the seat on the right side of the hydrolic unit.
J. Schwiebert
09-17-2004 17:16:57
 Re: Oliver Super 55 3 pt. hitch height adjustment? in reply to Larry from MD, 09-17-2004 15:01:05
Larry: Thanks for reminding me. It has been many years since I have done one.
1755
09-20-2004 19:24:47
 Re: Oliver Super 55 3 pt. hitch height adjustment? in reply to J. Schwiebert, 09-17-2004 17:16:57
Our 550 dont lift high enough sometimes on diferant things It lookes like the lift arms are on splines held on by a snap ring I have thought about terning it to the next spline but I dont know if it will
