Transmission problem
Geoffrey in KS
09-13-2004 17:31:59
I have a thunking noise in the transmission of my super 77. It increases in frequency in proportion to the tractor speed. I really don't feel anything but I sure can here it. I would like to have a look at it while I have the hydraulic unit off for repair. Any advice o what to look for?
Thanks,
Geoffrey
Larry U
09-16-2004 19:36:10
 Re: Transmission problem in reply to Geoffrey in KS, 09-13-2004 17:31:59
Do you have wheel weights? make sure they are tight if you have them, if loose, they will send noises.
Randy Lee
09-14-2004 06:06:32
It is not likley, but check your front wheel bearings. I have known of a person that had the same problem and the front wheel bearings was out and telegraphed through.
WFE
09-13-2004 21:15:22
Remove rear wheels and check axle bearings. If you're lucky, a replacement and proper shimming for bearing preload are all that's required. If it's too late, you may have a broken tooth on bull gear or pinion.
cobroller
09-14-2004 20:07:28
 Re: Transmission problem in reply to WFE, 09-13-2004 21:15:22
While you're checking around the rear end make sure the axle clamp bolts & rim clamp bolts are tight.
J. Schwiebert
09-13-2004 18:15:32
Have you taken the bull gear cover off and looked in there? Has your tractor had the magnetic drain plugs installed? If so were there any metal pieces of size on the plugs? Does it do it in every gear? Does it make the noise in reverse?
Have you checked any bearings for damage or incorrect clearance? some things to start with. Good Luck
Geoffrey in KS
09-14-2004 05:55:15
 Re: Transmission problem in reply to J. Schwiebert, 09-13-2004 18:15:32
I haven't looked in it yet. I don't know about the magnetic drain plugs, I haven't had them out yet. Yes, it does it in every gear including reverse. I have not checked the bearings yet.
Thanks,
Geoffrey
evielboweviel
09-13-2004 17:49:10
a broken/missing gear tooth
good luck
Ron
