hercules engine question
mikeythetreekiller
09-11-2004 19:25:43
What is the differance between a 1XB and a ZXB hercules engine. Thanks
J. Schwiebert
09-12-2004 05:51:39
 Re: hercules engine question in reply to mikeythetreekiller, 09-11-2004 19:25:43
They are 2 distint models. The last letter is a code for the bore size. The first letter is the basic model. The Z series are small engines roughly in the 60 cubic inch size. The 2 most common models are the ZXA & ZXB. The IX series are more common. The IXB is the largest bore size at 3-1/4 inch and they were even listed with a 2-3/4 inch bore. The IXA is a 3 inch bore engine. The IXK is a 3.125 bore and most of them must have been used in HG crawlers. Both engines were also made with either 3 or 5 timing gears. Left hand rotation (boat motors) and engine with stroker cranks were also built. There were also military versions of each. Hope this helps. Questions?
