Super 55 3 point lift
Kevin2
09-06-2004 18:02:45
My Super has recently developed a problem in the three point lift. In Draft position it works perfectly. However in full lift it is now hit or miss. Sometimes it goes up halfway and I can easily assist it the rest of the way up with one hand from the seat.(with implement on) Other times nothing, although as I switch it from lift to draft it will jump a little. I replaced the fluid and filter and no change. Anyone know whats going on? Thanks.
Sam Reaves
09-09-2004 04:04:38
 Re: Super 55 3 point lift in reply to Kevin2, 09-06-2004 18:02:45
My 550 did something similar to what you are desribing.... i also changed fluid and filter without any luck. The local oliver mechanic told me that he tought it was the valve getting stuck or the valve spring....could be from rust or dirt.
Told me to peck it a little with a small hammer around the filter area...did this a couple times and as of last weekend the problem hasn't returned.
Hope this helps a little
