77 Diesel wiring whoops
Eric-IA
09-06-2004 16:09:14
I reciently restored my 77D and rewired it to the IT wiring diagram specs... except for the fact I crossed the 2 12v batteries making 24v and made the generator smoke after running it for 10 minutes. I missed the detail that the original diagram crossed up 2 6v's.
What do I need to look at replacing?
J.Schwiebert
09-06-2004 17:39:30
 Re: 77 Diesel wiring whoops in reply to Eric-IA, 09-06-2004 16:09:14
Most likely a voltage regulator and maybe a generator since it was smoking, You will need to check things. It will not crank over as fastnow. You will need to hook the two negative terminal together and the two positive terminals to keep the 12 volt if you stay with the same batteries.
