Super 55 external hydraulic control
km07
09-02-2004 06:47:54
Ok - I'm confused. Where would the control be if it had one? I have a lever under the seat (draft control?) right beside is a knob with hi lo and a sequence of numbers. It has two outlets on the block the lever is attached to and they are plugged off. Is there a pic floating around of one? Thx Again!
J. Schwiebert
09-02-2004 09:12:31
 Re: Super 55 external hydraulic control in reply to km07, 09-02-2004 06:47:54
That is your remote valve. You did not give a serial number , but if your hydraulic filter is in the front of the hydraulic unit and is a cast housing with a hex for a wrench cast in it you have a later unit and there is no handle for draft control. If not there will be another handle farther back that is for draft and position control. The two plugged ports are where your hoses would go to your break-a-way for training implements. The numbers are for adjusting flow to the breakaway.
Mike (WA)
09-02-2004 09:11:05
Sounds like you have the authentic item- The block should be on the right front side of the transmission case- lever mounted to the front of it, which controls two hydraulic spools. With the tractor running and the ports plugged, it should lug the tractor down when you engage the lever either way, and you should hear the "screech" of a hydraulic bypass valve
