550 diesel not running
Jeff Oliver
08-31-2004 16:36:21
We have a Oliver 550 Diesel that will run as long as you shoot ether to it but no without it. I has been sitting for a couple of years but was running before it was parked. Dad said he got fuel to the pump but not up to the injectors. He found the low sie bleed valve but couldn' find the other one or something. Could it just need more bleeding? That is what weare thinking but if anyone else knows of something ot check or try I would appreciate it!
Jeff
J. Schwiebert
08-31-2004 18:14:23
 Re: 550 diesel not running in reply to Jeff Oliver, 08-31-2004 16:36:21
Is this a Bosch or Roosa Master Pump
Larry from MD
08-31-2004 17:28:46
The main plunger could have stuck or the govner pin/rocker could be stuck.But first i would pull it with another tractor or heavy picup and see if you could spin it real good.
Jeff Oliver
09-01-2004 03:26:02
 Re: 550 diesel not running in reply to Larry from MD, 08-31-2004 17:28:46
I'm not sure which pump it is as I have not been up there to look at it yet. I think we looked at the serial number and it is a 1958 model but can't remember right now if that helps.
As for pulling it , right now one of the rear rims is rusted off of it but we have another set. When we get it on there I will try that.. Thanks!
