770 rowcrop
B Griffin
08-31-2004 04:19:03
I have a 1958 770 rowcrop that I just picked up. It had sat for about 5 years. Got it running, installed new gauges and in the process of other repairs. Problem is I cant' get the govenor to allow it to turn up past about 1500 rpm. I ahve adjusted the control linkage and I only get an rpm increase of about 900-1000 rpm. If I adjust the linkage I can get 18-1900 rpm, but it wont' idle back down below 1000+-. Opening the throttle by hand will make it turn up, can't get the govenor to allow the high no load speed. I'm stumped, any suggestions. I'm fairly familiar w/ the setup as I also have a 1950 66 rowcrop. Sorry for the long post.(carb is also rebuilt)
J. Schwiebert
08-31-2004 06:23:41
 Re: 770 rowcrop in reply to B Griffin, 08-31-2004 04:19:03
Double check to see how many active coils you have in the spring. If I remember correctly you need 19. Remember the old rule, spring tension increases speed, centrifugal force from the weights take the speed away.
J. Schwiebert
08-31-2004 07:27:24
 Re: 770 rowcrop in reply to J. Schwiebert, 08-31-2004 06:23:41
I forgot to ask have you had the weight assembly out and checked the condition of the thrust bearing, washer and pivot pins?
B Griffin
08-31-2004 08:06:51
 Re: 770 rowcrop in reply to J. Schwiebert, 08-31-2004 07:27:24
Thanks for the response, I've got good spring tension and no i haven't been inside the govenor yet, i was hoping that there may be something about the linkage or something simple i was missing. i guess I was just being lazy. I also have the tractor somewhat disassembled so i can't get it out and put it under load yet. Just got it rewired and running late last night, so there are still things to go through, thanks again!
