OC-3 problem running when it gets warmed up
old
08-29-2004 14:48:18
I have an OC-3 that after about 30-60 minutes of running it starts to loose power and if it dies it will not start for about 2/3 hours. Could it be that the Mag is going bad??
Thanks for any ideas
Karen
08-31-2004 04:18:23
 Re: OC-3 problem running when it gets warmed up in reply to old, 08-29-2004 14:48:18
Sounds like you have a bad coil or condenser, but more likely coil if it's weak or no spark after it gets hot. We have these parts in stock. Email me.
old
08-31-2004 19:16:42
 Re: OC-3 problem running when it gets warmed up in reply to Karen, 08-31-2004 04:18:23
Karen I have tried to send you an e-mail but keep comeing up with an error message please send me an e-mail with price of both parts.
Thanks
J. Schwiebert
08-29-2004 16:40:44
After it quit running did you pull a plug wire off and see if you have a good blue spark?
old
08-29-2004 16:46:52
 Re: OC-3 problem running when it gets warmed up in reply to J. Schwiebert, 08-29-2004 16:40:44
The spark seems to be weak after it stops, and it also seems to have water in the cap area after it stops also.
RockinB
08-30-2004 12:58:18
 Re: OC-3 problem running when it gets warmed up in reply to old, 08-29-2004 16:46:52
I've got an OC 3 that acts the same.Sure would like to solve the problem.Hopefully you'll post the solution when you find it.
old
08-30-2004 13:14:46
 Re: OC-3 problem running when it gets warmed up in reply to RockinB, 08-30-2004 12:58:18
I will if I find out whats wrong
