Cockshutt 560
Andrew
08-28-2004 21:02:35
Does anyone know what the bore and stroke is for the 269 Perkins also what RPM did they run??? any ifon woudl be a big help thanx
P Heisey-Harleysville,PA
08-29-2004 03:31:23
 Re: Cockshutt 560 in reply to Andrew, 08-28-2004 21:02:35
Andrew,
Cockshutt 560 with Perkins Engines, L4 (1958 only) and 4-270, 1959-1962: Bore 4.25 inches. Stroke 4.75 inches. RPM, no load, 1850, RPM loaded, 1650.
Please let me know when I can assist you further.
Phil Heisey 215-256-8651 FAX 215-256-1203
Andrew
08-29-2004 09:27:02
 Re: Cockshutt 560 in reply to P Heisey-Harleysville,PA, 08-29-2004 03:31:23
would you know the bore and stroek of that 540 with the 162 Cont engine???? Thank you very much
J. Schwiebert
08-29-2004 16:38:29
 Re: Cockshutt 560 in reply to Andrew, 08-29-2004 09:27:02
3.437 bore 4.375 stroke. The F-124, F-140 & F 162 all have the same stroke
